OSPF Redundancy
14 years 5 months ago #37253 by payeh
OSPF Redundancy was created by payeh
Hi all,
I have a problem about how to make OSPF redundancy, lets me explain the condition(refer to the diagram):
File Attachment:
[img][http://www4.picturepush.com/photo/a/6170687/640/6170687.jpg[/img]
www.mediafire.com/file/r78jzaglgu2z3mz/ospf3.pkt
There are 4 layer 3 switches:
- 2 Core switches (C1 & C2)
- 2 Distributions (D1 & D2)
C1
Vlan 2 -192.168.1.2/29
Vlan 3 -192.168.2.2/29
C2
Vlan 2 -192.168.1.3/29
Vlan 3 -192.168.2.3/29
D1
Vlan 2 -192.168.1.4/29
Vlan 4 -10.10.10.1/24
D2
Vlan 3 -192.168.2.4/29
Vlan 5 -10.10.20.1/24
I can ping from PC0 to PC1, but I when i test redundancy by shutdown LINE 1 its not working. Ping is dropped. I dont know what the problem (maybe something wrong with configuration).
I have uploaded pracket tracer file. Hope anybody can help me.
Many Thanks,
Payeh
14 years 5 months ago #37254 by Nevins
Replied by Nevins on topic Re: OSPF Redundancy
I haven't done a lot with layer 3 switching but the links between switches be trunk links right?
[code:1]D1#show interfaces trunk
D1#[/code:1]
[code:1]!
interface FastEthernet0/1
switchport access vlan 2
interface FastEthernet0/2
switchport access vlan 4
interface FastEthernet0/3
![/code:1]
Try this link
pre.visualland.net/view.php?cid=939&...r%203%20switch%20lab
Useful Threads
14 years 5 months ago #37258 by S0lo
Replied by S0lo on topic Re: OSPF Redundancy
I had a look at it, There were 3 main problems:
1. Fa0/3 on D2 is on VLAN5. It should be on VLAN 3, since the other end of the cable is on VLAN 3
2. C2 was not doing routing. So I added the ip routing command.
3. Networks 10.10.10.0/24 and 10.10.20.0/24 were advertized on OSPF area 2. I moved them to area 1. If you want them on area 2 then I think you have REDISTRIBUTE routes.
I also removed all static routes since OSPF can do the job. After those changes, the 2 PCs can ping each other no matter what single cable you remove. If it doesn't work immediately after you remove a cable, just wait for it so that OSPF converges. Here is the fixed file:
www.mediafire.com/?usd233dd8p27glg
14 years 5 months ago #37260 by rizin
Replied by rizin on topic Re: OSPF Redundancy
Good Job Ammar :)
14 years 5 months ago #37261 by S0lo
Thanks rizin :) hope it help payeh.
14 years 5 months ago #37262 by payeh
Replied by payeh on topic Re: OSPF Redundancy
Thanks all for the reply,
To Solo,
So you just make changes:
1-change f0/3 to vlan 3
2-add ip routing on c2
3-move Networks 10.10.10.0/24 and 10.10.20.0/24 to area 1
did u put ip for the loopback interface?
FYI i cannot open your file because im using the older version of packet tracer,if possible maybe you can provide me link to download latest version.
Many thanks
